Newsat11
Aug 28, 2015Luminary
Setting phpMyAdmin
After installing the application the setup screen states I need a config folder. The installation directions are not clear to me. It says I have to create the config folder in the root directory. I am...
gpaolo
Dec 15, 2015Luminary
Hello, I have the same problem.
I'm trying to set up Drupal but before I have to install MySQL ---and before I have to install phpMyAdmin.
The setup want fine, but when I open it I also get this message saying that I have to create a "config" directory.
I'm checking on SSH if I find any obvious place where to create it but no luck until now.
Could someone please give me some instructions?
I'm using a RN314 with OS6. Thanks!
Newsat11
Jan 04, 2016Luminary
Sorry, I just saw this...The config directory is installed when you install PHP. Have you fixed your problem yet? Before installing any of the listed add-ons you have to install PHP. You should start by uninstalling everything and starting with PHP.
- gpaoloJan 04, 2016Luminary
Hi, no problem ;)
Thank you for the instructions, I managed to have it running after a few days of trials and errors (mostly errors, actually).
The problem is that now I don't really remember how I fixed the issue, but it is possible that I ended up uninstalling and reinstalling everything in the correct order.
- Newsat11Jan 06, 2016Luminary
My guess it that you uninstalled everything as well. There is something to be said for trial and error, but here is a quick rundown of what was going on. All the programs you installed were dependent on a successful installation of PHP. The config file is generated when PHP is successfully installed (it can be a pain to get to but that's another story). phpMyAdmin allows you to manipulate the database without having to learn mySQL. but it's a good skill to have. If you need to get on some MySQL knowledge, you can take a basics course for free from Code Academy. For an online coding site their programs are pretty good. Let me know if you need any help, I am pushing the Netgear equipment to it's maximum capabilities so by the time I am done I should be a great resource for those looking for small business IT solutions.
- gpaoloJan 10, 2016Luminary
Thank you very much for your offer!
I have experience in low level programming, but almost nothing in (modern) PC programming. I was trying to get Drupal running on my NAS to host a small website, but after trying it I decided that it was not what I needed and I moved to a normal website designed with standard tools, so at the end I'm not using PHP/MySQL/Drupal any more, but maybe in the future I may get back to it.
