Newsat11
Aug 28, 2015Luminary
Setting phpMyAdmin
After installing the application the setup screen states I need a config folder. The installation directions are not clear to me. It says I have to create the config folder in the root directory. I am...
Newsat11
Jan 04, 2016Luminary
Sorry, I just saw this...The config directory is installed when you install PHP. Have you fixed your problem yet? Before installing any of the listed add-ons you have to install PHP. You should start by uninstalling everything and starting with PHP.
gpaolo
Hi, no problem ;)
Thank you for the instructions, I managed to have it running after a few days of trials and errors (mostly errors, actually).
The problem is that now I don't really remember how I fixed the issue, but it is possible that I ended up uninstalling and reinstalling everything in the correct order.
