testing123456
Oct 16, 2018Initiate
SickRage taken over update no longer works, use SickChill
Not sure who noticed that after an update Sickrage stopped working, if you then try to download a new version you land on the sickrage.ca page. If you install that version and want to access the ...
testing123456
How to change your current install to point to the new SickChill repository
https://github.com/SickChill/SickChill/issues/5022
Some background
https://www.reddit.com/r/sickrage/comments/9ll427/echelon_attempting_hostile_takeover_again/
Dave
longsifu
Nov 09, 2018Aspirant
Can someone help me(noob) how to do this change properly on my ReadyNAS 204? This is what I've tried to do.
- Stop SickRage from the ReadyNAS app page.
- ssh to my readynas
- edit /apps/sickrage/app-config/config.ini
- Replace "git_remote_url = https://github.com/SickRage/SickRage.git" with "git_remote_url = https://github.com/SickChill/SickChill.git"
- Save config.ini
- Restart SickRage from ReadyNAS app page.
checking the status gives me this:
admin@readynas:/apps/sickrage/app-config$ systemctl status fvapp-sickrage
● fvapp-sickrage.service - Service for sickrage app
Loaded: loaded (/lib/systemd/system/fvapp-sickrage.service; enabled; vendor p
reset: enabled)
Active: active (running) since Fri 2018-11-09 22:58:41 CST; 1s ago
Main PID: 21649 (python)
CGroup: /system.slice/fvapp-sickrage.service
└─21649 /usr/bin/python /apps/sickrage/SickBeard.py --nolaunch --data
dir=/apps/sickrage/app-config --config=/apps/sickrage/app-config/config.ini --po
rt=6765
But I still can't connect to sickrage. Connection refused. Was there something else I was suppose to do?
Thanks
Nathan
