mbayrock
Dec 06, 2013Follower
Softether VPN Server help
I've got the softether VPN server running and I can connect to the VPN no problem, I can then see and broswe directly to my computers connected to that network, but I cannot see nor access the ReadyNa...
olest
Dec 28, 2013Guide
For that to work you to make a tap interface and enable securenat. Then you can access the virtual ip on the tap interface through the vpn.
Sendt fra min GT-I9300 med Tapatalk2
