mbayrock
Dec 06, 2013Follower
Softether VPN Server help
I've got the softether VPN server running and I can connect to the VPN no problem, I can then see and broswe directly to my computers connected to that network, but I cannot see nor access the ReadyNa...
stealthius
Feb 13, 2014Aspirant
Has anyone been able to achieve this? As Olest said you have to create a TAP interface, i did that, still unable to connect to the readynas itself. All other IP addresses within the network are accessible correctly.
I have tried this with 1 single TAP device in Local Bridge settings
I have tried this with 1 TAP device and 1 Eth adapter in Local Bridge settings.
Both times used SecureNAT configuration. both results were the same, everything accessible on the network but NOT anything hosted on the readynas. I tried connecting to the Actual IP address of my readynas and the IP address of the SecureNAT interface. Still no go.
What am i missing here or doing wrong? Any help would be greatly appreciated.
I am using the latest VPN server version 1.3.0
P.S I did read the following article by Softether in the troubleshooting section:
11.1.2 I am unable to communicate with the IP address of the Virtual Network Adapter used for local bridging from within the VPN.
if you are using Linux or Solaris, you can communicate within the Virtual Hub (VPN) from the network adapter connected to by the local bridge to the LAN, but you can not communicate to the network adapter itself. This is a restriction imposed by the Linux kernel. For more information please refer to 3.6 Local Bridges.
So that would make sense why it is not working, and i do understand the use of the TAP device to work around this, but how?
Thank you
Thank you
