BSRdr
Apr 07, 2017Aspirant
Sonarr on 6.7
I've been running Sonarr on my 516 pre 6.7 firmare successfully using the following instructions: Putty in after enabling SSH Install starts here: apt-key adv --keyserver keyserver.ubuntu...
BSRdr
Hmm I'm still getting:
root@MediaNAS:~# apt-get install libmono-cil-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libmono-cil-dev : Depends: libmono-http4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-microsoft-web-infrastructure1.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-data-services4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-design4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-drawing4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-drawing-design4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-messaging4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-reactive-windows-forms2.2-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-runtime4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-servicemodel4.0a-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-servicemodel-activation4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-servicemodel-discovery4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-servicemodel-routing4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-servicemodel-web4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-serviceprocess4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-abstractions4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-dynamicdata4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-extensions4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-extensions-design4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-http-selfhost4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-http-webhost4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-mvc3.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-routing4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-services4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-webpages2.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-webpages-deployment2.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-web-webpages-razor2.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-windows-forms4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-windows-forms-datavisualization4.0a-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libmono-system-xml-serialization4.0-cil (= 4.2.1.102+dfsg2-6) but it is not going to be installed
Depends: libnunit-cil-dev (>= 2.4) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
root@MediaNAS:~#
F_L_
Apr 07, 2017Tutor
strange, did you do the apt-clean and autoclean ?
