BSRdr
Apr 07, 2017Aspirant
Sonarr on 6.7
I've been running Sonarr on my 516 pre 6.7 firmare successfully using the following instructions: Putty in after enabling SSH Install starts here: apt-key adv --keyserver keyserver.ubuntu...
BSRdr
Apr 08, 2017Aspirant
Figured it out - had to nano out the repository from /etc/apt/sources.list.d/sonarr.list
Totally user error on my part :) Surprised no one has created a package for it yet
JBDragon1
May 28, 2017Virtuoso
I was having issues with my ReadyNAS 516, and figured what the hell, I'll wipe it and start over. I had backup of my Data, and I took pictures of all my settings in PLEX, PlexPl, NZBGet, Sonarr, and CouchPotato. Just in case I had issues with the config files. Good thing I did that.
A big help in creating the autostart files I needed instead of using something like vim or in your case nano is a program called WinSCP. Then I could go where I wanted easily, create a new file, Put in it what I needed, save it and change the permitions for it.
So now I have NZBGet, Sonarr, and Radarr (CouchPotato Replacment) all running and autobooting. If you like Sonarr, you'll like Radarr. It's still in deveopment, but seems to work just fine. NZBGet I couldn't update from in the program when I installed a 17.1 deb version. Installing by SSH, that now works. So they can all update from in the program. PlexPl will also update in it's own program, even though I installed that the normal deb file way. Plex I have to do as always, shut it down, and install a new deb copy and then turn it back on.
Running OS 6.7.4
It would be nice if there was a package for all of them and they all worked like they should. You have to do what you have to do. Thank goodness for Google. Hunting down that data I needed to know to get it all working.
- JBDragon1Jun 10, 2017Virtuoso
Does anyone know how to install a newer version of MONO? Right now I have Debian 4.2.1.102+dfsg2-6 installed even though there's a stable 5.0.1.1 version. I keep trying to do what the instructions says, but I keep being told there isn't a newer version. I'm following the directions here, and still, it won't go newer.
http://www.mono-project.com/download/#download-lin-debian
This is on my ReadyNAS 516. I'm stumped. I'm not a Linux expert. I'm following directions for Debian 8. Just no go.
- stevevandegaer2Jul 14, 2017Tutor
Tried this and getting
root@NG-NAS:/etc/apt# apt-get install nzbdrone
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package nzbdrone- TeknoJnkyJul 14, 2017Hero
it can't find the package it doesn't seem you have added the repository (or didn't add it correctly).
also before you add the nzbdrone repo, you should use apt-get to install mono first
apt-get install libmono-cil-dev
