BSRdr
Apr 07, 2017Aspirant
Sonarr on 6.7
I've been running Sonarr on my 516 pre 6.7 firmare successfully using the following instructions: Putty in after enabling SSH Install starts here: apt-key adv --keyserver keyserver.ubuntu...
JBDragon1
May 27, 2017Virtuoso
I was having issues with my ReadyNAS 516, and figured what the hell, I'll wipe it and start over. I had backup of my Data, and I took pictures of all my settings in PLEX, PlexPl, NZBGet, Sonarr, and CouchPotato. Just in case I had issues with the config files. Good thing I did that.
A big help in creating the autostart files I needed instead of using something like vim or in your case nano is a program called WinSCP. Then I could go where I wanted easily, create a new file, Put in it what I needed, save it and change the permitions for it.
So now I have NZBGet, Sonarr, and Radarr (CouchPotato Replacment) all running and autobooting. If you like Sonarr, you'll like Radarr. It's still in deveopment, but seems to work just fine. NZBGet I couldn't update from in the program when I installed a 17.1 deb version. Installing by SSH, that now works. So they can all update from in the program. PlexPl will also update in it's own program, even though I installed that the normal deb file way. Plex I have to do as always, shut it down, and install a new deb copy and then turn it back on.
Running OS 6.7.4
It would be nice if there was a package for all of them and they all worked like they should. You have to do what you have to do. Thank goodness for Google. Hunting down that data I needed to know to get it all working.
JBDragon1
Jun 09, 2017Virtuoso
Does anyone know how to install a newer version of MONO? Right now I have Debian 4.2.1.102+dfsg2-6 installed even though there's a stable 5.0.1.1 version. I keep trying to do what the instructions says, but I keep being told there isn't a newer version. I'm following the directions here, and still, it won't go newer.
http://www.mono-project.com/download/#download-lin-debian
This is on my ReadyNAS 516. I'm stumped. I'm not a Linux expert. I'm following directions for Debian 8. Just no go.
- stevevandegaer2Jul 14, 2017Tutor
Tried this and getting
root@NG-NAS:/etc/apt# apt-get install nzbdrone
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package nzbdrone - TeknoJnkyJul 14, 2017Hero
it can't find the package it doesn't seem you have added the repository (or didn't add it correctly).
also before you add the nzbdrone repo, you should use apt-get to install mono first
apt-get install libmono-cil-dev
libmono-cil-dev is already the newest version (4.2.1.102+dfsg2-6).
W: The repository 'http://apt.sonarr.tv/4 master Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://us.archive.ubuntu.com/ubuntu/93 trusty Release' does not have a Release file.
W: The repository 'http://us.archive.ubuntu.com/ubuntu/93 trusty-updates Release' does not have a Release file.
E: Failed to fetch http://apt.sonarr.tv/4/dists/master/main/binary-amd64/Packages 404 Not Found
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/93/dists/trusty/universe/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/93/dists/trusty-updates/universe/binary-amd64/Packages 404 Not Found [IP: 91.189.91.23 80]
E: Some index files failed to download. They have been ignored, or old ones used instead. - TeknoJnkyJul 15, 2017Hero
you have the a bad repo in one of your lists.
there shouldn't be any 'trusty' repo, os6 is using debian 'jessie'
the instructions at the top of the thread worked for me.
also, it seems any time you upgrade os6, you have to re-enter this command;
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys FDA5DFFC
- stevevandegaer2Jul 16, 2017Tutor
On the link above it says to add
Second add new Repos
add-apt-repository "deb http://us.archive.ubuntu.com/ubuntu/93 trusty universe multiverse"
add-apt-repository "deb http://us.archive.ubuntu.com/ubuntu/93 trusty-updates universe multiverse" - stevevandegaer2Jul 16, 2017Tutor
Now I get
root@NG-NAS:~# apt-get install nzbdrone
E: Unable to locate package nzbdroneroot@NG-NAS:~# apt-get update
Hit:1 http://egnyte-cdn.egnyte.com/storagesync/netgear6/en-us 6.7 InRelease
Get:2 http://security.debian.org jessie/updates InRelease [63.1 kB]
Ign:3 http://apt.sonarr.tv/4 master InRelease
Ign:4 http://apt.sonarr.tv/4 master Release
Hit:5 http://apt.readynas.com/packages/readynasos 6.7.5 InRelease
Ign:6 http://apt.sonarr.tv/4 master/main amd64 Packages
Ign:7 http://apt.sonarr.tv/4 master/main all Packages
Ign:8 http://mirrors.kernel.org/debian jessie InRelease
Hit:9 http://mirrors.kernel.org/debian jessie Release
Get:10 http://security.debian.org jessie/updates/main amd64 Packages [424 kB]
Err:6 http://apt.sonarr.tv/4 master/main amd64 Packages
404 Not Found
Fetched 487 kB in 1s (334 kB/s)
E: Some index files failed to download. They have been ignored, or old ones used instead. - TeknoJnkyJul 16, 2017Hero
I don't know what link your following but trusty is a different version of linux and obviously will not work on your readynas which uses debian jessie, not trusty..
Follow the steps in the very first post of this thread, ignore that post about mono version 5.
- TeknoJnkyJul 17, 2017Hero
did you do this?
- stevevandegaer2Jul 17, 2017Tutor
Yes I did that
