chirpa
Jul 13, 2009Luminary
Sparc platform development envrionment using Qemu
You can now run a fully emulated Sparc platform development environment on any system capable of running Qemu. Download: readynas_compile_environment.qcow.gz # wget -q http://www.readynas.com/d...
scott_alan_klin
Jul 24, 2009Tutor
I am trying to use this on Ubuntu so I can compile the full_audit.so for samba but every time I try to start I get the error:
I have looked everywhere trying to find a resolution and I can't find anything. I did look within the /usr/share/qemu and it has symlinks to a folder called openbios from all of the files begining with openbios- (like openbios-sparc32) but the actual folders they are linking to do not exist. I have done an update and reinstall of qemu but it is the same, I also removed and installed from a debian package, still the same thing.
Thanks in advance,
SK
qemu-system-sparc -hda readynas_compile_environment.qcow -nographic
/usr/share/qemu/openbios-sparc32: No such file or directory
qemu: could not load prom '/usr/share/qemu/openbios-sparc32'
Thanks in advance,
SK
