chirpa
Jul 13, 2009Luminary
Sparc platform development envrionment using Qemu
You can now run a fully emulated Sparc platform development environment on any system capable of running Qemu. Download: readynas_compile_environment.qcow.gz # wget -q http://www.readynas.com/d...
kiwi1969
Aug 19, 2011Aspirant
The QEMU image is not based on RAIDiator, so you can't upgrade the QEMU image to 4.1.7. It is just a Sparc emulated Debian Linux, that can be used to compile code to run on the ReadyNAS.
So, if I compile something on the QEMU virtual machine, is the resulting object binary compatible with the NV+ ?
ie Can I just copy and run, or do we have to recompile the source on the NV+ ?
What OS is actually running on the NV+ ?
