chirpa's avatar
chirpa
Luminary
Jul 13, 2009
Sparc platform development envrionment using Qemu
You can now run a fully emulated Sparc platform development environment on any system capable of running Qemu.
Download: readynas_compile_environment.qcow.gz
# wget -q http://www.readynas.com/download/development/readynas_compile_environment.qcow.gz
# gunzip readynas_compile_environment.qcow.gz
# qemu-system-sparc -hda readynas_compile_environment.qcow -nographic
Default root password for this package is 'a'. The compile environment is all there for most common stuff.
(qemu)
Nvram id QEMU_BIOS, version 1, machine id 0x80
CPUs: 1
invalid nvram partition length
nvram error detected, zapping pram
Welcome to OpenBIOS v1.0RC1 built on May 31 2007 23:50
Type 'help' for detailed information
[sparc] Booting file 'disk' with parameters ''
Not a bootable ELF image
Not a Linux kernel image
Loading a.out image...
Loaded 7680 bytes
entry point is 0x4000
Jumping to entry point...
SILO Version 1.4.13
boot:
Uncompressing image...
Loaded kernel version 2.6.18
Loading initial ramdisk (3210249 bytes at 0x3000000 phys, 0x60000000 virt)...
PROMLIB: obio_ranges 1
Booting Linux...
PROMLIB: Sun Boot Prom Version 3 Revision 2
Linux version 2.6.18-6-sparc32 (Debian 2.6.18.dfsg.1-23etch1) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 Fri Dec 12 16:29:52 UTC 2008
ARCH: SUN4M
TYPE: SPARCstation 5
Ethernet address: 52:54:0:12:34:56
Boot time fixup v1.6. 4/Mar/98 Jakub Jelinek (jj@ultra.linux.cz). Patching kernel for srmmu[Fujitsu TurboSparc]/iommu
PROM: Built device tree with 21266 bytes of memory.
Power off control detected.
Built 1 zonelists. Total pages: 31179
Kernel command line: root=/dev/sda2 ro
PID hash table entries: 512 (order: 9, 2048 bytes)
start_kernel(): bug: interrupts were enabled early
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 121200k/130232k available (1640k kernel code, 8880k reserved, 404k data, 136k init, 0k highmem)
Mount-cache hash table entries: 512
checking if image is initramfs... it is
Freeing initrd memory: 3135k freed
NET: Registered protocol family 16
IOMMU: impl 0 vers 4 table 0xf3200000[262144 B] map [65536 b]
sbus0: Clock 21.1250 MHz
dma0: Revision 2
dma1: Revision 2
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 4096 bind 2048)
TCP reno registered
ioremap: done with statics, switching to malloc
apc: power management initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Console: switching to colour frame buffer device 128x48
/iommu@0,10000000/sbus@0,10001000/SUNW,tcx@3,800000: TCX at 0:50800000, 24-bit depth
ffd54490: ttyS0 at MMIO 0x71100000 (irq = 44) is a zs
Console: ttyS0 (SunZilog zs0)
ffd54490: ttyS1 at MMIO 0x71100004 (irq = 44) is a zs
ffd5466c: Keyboard at MMIO 71000000 (irq = 44) is a zs
ffd5466c: Mouse at MMIO 71000004 (irq = 44) is a zs
Floppy drive(s): fd0 is 1.44M
FDC 0 is a S82078B
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
rtc_sun_init: Registered Mostek RTC driver.
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 136k freed
input: Sun Type 5 keyboard as /class/input/input0
Loading, please wait...
Begin: Loading essential drivers... ...
SCSI subsystem initialized
esp0: IRQ 36 SCSI ID 7 Clk 40MHz CCYC=25000 CCF=8 TOut 167 NCR53C90(esp100)
scsi0 : Sparc ESP100 (NCR53C90)
Vendor: QEMU Model: QEMU HARDDISK Rev: 0.8.
Type: Direct-Access ANSI SCSI revision: 03
Vendor: QEMU Model: QEMU CD-ROM Rev: 0.8.
Type: CD-ROM ANSI SCSI revision: 03
Done.
Begin: Running /scripts/init-premount ...
SCSI device sda: 20971521 512-byte hdwr sectors (10737 MB)
sda: Write Protect is off
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3 sda4
sd 0:0:0:0: Attached scsi disk sda
Done.
Begin: Mounting root file system... ...
Begin: Running /scripts/local-top ...
Done.
Begin: Running /scripts/local-premount ...
Done.
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Begin: Running /scripts/local-bottom ...
Done.
Done.
Begin: Running /scripts/init-bottom ...
Done.
INIT: version 2.84 booting
INIT: Entering runlevel: 3
EXT3 FS on sda2, internal journal
sunlance.c:v2.02 8/24/03 Miguel de Icaza (miguel@nuclecu.unam.mx)
SunLance: using auto-carrier-detection.
eth0: LANCE 52:54:00:12:34:56
Starting LVM...done.
Checking filesystems...done
Setting kernel variables.
Mounting filesystems:
nothing was mounted
Initializing urandom... done.
Starting portmap...done.
Starting log daemons: syslogd klogd.
Starting atd...done
Starting inetd...done
Starting cupsd...done
Starting cron...done
debian-sparc login: root
Password:
Linux debian-sparc 2.6.18-6-sparc32 #1 Fri Dec 12 16:29:52 UTC 2008 sparc GNU/Linux
debian-sparc:~#
(I'm actually running this directly on a ReadyNAS Pro)
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Developers running Windows 7 may wish to take a look at this video by @syke:
  • I can do another one for recent versions of Linux/MacOS if need be, but this one is detailed enough that users of other platforms should be able to translate the steps.
    I hope this helps, please leave feedback and thumbs it up. If anyone is in the giving mood after watching, please buy some of my band's songs @ http://themakingofthemakingof.com :)
  • Hello,
    I tried to run qemu under windows7 by using the image. But when I enter the command as in the video posted nothing happens. As you said, there will no error be displayed I have no idea what I did wrong.
    Uploaded with ImageShack.us
  • Great video, I'm up and running with the Qemu dev env. Now to have a crack at getting bluetooth support working...
  • So, the past days I got time to try this qemu thing again, and now its working! :) Thanks matt_hargett . Is there also a way to access the webinterface of the nas? Entering the IP Adress of the qemu results into a 404 error. (running it on windows7 with enabled iis)
    EDIT:
    You have to start the service by your self. /etc/init.d/frontview start
    and
    passwd admin
    Enter new UNIX password:
    Retype new UNIX password:
ProSupport for Business
