TeknoJnky
Mar 06, 2014Hero
subsonic 4.9
any chance of an updated package for subsonic 4.9/raidiator 4.x?
- SamosAspirantThanx.
With the update of your mod, i'have this message :
"Somme de contrôle du fichier image incorrecte. Mise à jour abandonnée."
An idea ??
:) - SamosAspirantNow, I want desinstall your addon, to retry the installation, but i have the same message :
How can i properly desinstall it ? - RedDeathAspirantWas this ever updated? Does it install properly now? I would love to update my subsonic.
The dropbox shows it's 14 days old so I am unsure.
Thanks! - RedDeathAspirantI went with the install. I couldn't install through frontpage, but was able to SSH and run the install.sh script.
Super-poussin did fix the java line. Works great.
The UI in 4.9 is so much nicer than 4.7.
Thanks again Super-poussin, you rock, I appreciate it. - Dewdman42Virtuosowhere is the community dropbox to get 4.9?
- I would like more information on how to update to 4.9. I apologize for being a Linux newbie but we all have to start somewhere. I have the 1.04 file from the community Dropbox. How do I transfer the file? I believe I need to run sh install.sh but how do we unpack the DEB file to get the install file?
Dropbox location for Dewdman42: https://www.dropbox.com/sh/ie9pwk1wut72ias/p6_X2QeOIC - JeremyB132AspirantEdit: I found it was looking in the wrong area. Winnebago check in the x84 (4.2) folder in dropbox.
Edit 2: Here is the link https://www.dropbox.com/sh/ie9pwk1wut72ias/AAAoAz7LNr7a8ejC41DiKA4qa/x86-4.2/Subsonic_4.9.00.bin - Thank you, JeremyB132. I will D/L that and see what happens.
Did you have good luck installing and getting it all to work? - lancerusAspirantI might be able to help here.
First let me describe my environment ...
I'm (currently) running Subsonic-4.9 (with the extra features, ie: redirection from <name>.subsonic.org, etc).
I stream to work (the web interface).
I stream to my cars (iSub running on iphones)
In my house, I have Audioengine plugged into the nas (combo usb soundcard/wireless device) so I can run jukebox mode and broadcast to two stereos.
I have all of the above running against os4 (Pro6). I also had problems installing Super-Poussin's 4.9 build so I created a custom version.
Along the way I also created a build of Madsonic-5.0 (but havent tested it yet). I wanted to stablize the Audioengine path first before switching to Madsonic.
I've also run the entire environment against OS6 (Pro2) - but actually just switched to the os4/Pro6 as the Pro2 didnt have enough "juice" (couldnt transcode realtime, etc). On the OS6 version - when I was running that I did upgrade it to 4.9 by simply replacing the .war and restarting.
Anyway - any questions I'll gladly help. - lancerusAspirantI have one problem left I'm chasing on the os4 version ... once a day apache apparently restarts (I never noticed before, looks like its something normal). The catch is when apache restarts - it *stops* subsonic (cleanly) -- but doesnt restart it. In /var/log/frontview/error.log I have this:
[Sun Jul 13 06:25:04 2014] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8c DAV/2 PHP/5.4.25-0rnx1 SVN/1.7.4 mod_apreq2-20051231/2.6.0 mod_perl/2.0.2 Perl/v5.8.8 configured -- resuming normal operations
There's nothing in the logs about stopping subsonic ... but over in the subsonic logs, it received a sig 15 and did a clean shutdown. I'm not sure yet what the connection is - ie: why is subsonic getting sent the sig 15 to stop for an apache restart. Has anyone seen anything like this before and/or have any pointers about what needs to change with this package setup ?
Thanks !!!
