WhoCares_
Apr 10, 2015Mentor
Syncthing 0.11.19
Syncthing
Description
Syncthing replaces proprietary sync and cloud services with something open, trustworthy and decentralized. Your data is your data alone and you dese...
WhoCares_
Apr 11, 2015Mentor
Updated to:
Changes:
On installation of the new version the contents of the default folder will be moved automatically and the config will be adjusted. (Only if the folder is still in the default location of course)
Changes:
- Updated beta version to beta6
- Moved default sync folder to homedir of the admin user to prevent accidental filling up of the OS partition
WhoCares_
Aug 16, 2015Mentor
Updated to:
Changes:
