secret_rivals
Sep 16, 2009Aspirant
Torrentflux stopped connecting to torrents
I have been using Torrentflux for months with no problems at all. The other week my torrents stopped connecting to the trackers (new ones and existing ones). The error message I get is warning - cry...
secret_rivals
May 02, 2010Aspirant
Does anyone know how to update python-crypto onto the ReadyNAS. I have the Apt plugin installed and I have read on the Torrentflux forums to update the python-crypto files with apt-get install python-crypto http://www.torrentflux.com/forum/index.php?topic=4040.msg22047. I am hesitant in running this apt get command because of this warning on the ReadyNAS webste: http://www.readynas.com/?p=145 "Please note that you can get your ReadyNAS into peril easily by overriding some of the system libraries and utilities. Do not do your development on a system you don’t have a backup of as you may end up re-installing the firmware or worse yet, doing a factory default."
super-poussin do you think I will brick my ReadyNAS if I run apt-get install python-crypto ?
