secret_rivals
Sep 16, 2009Aspirant
Torrentflux stopped connecting to torrents
I have been using Torrentflux for months with no problems at all. The other week my torrents stopped connecting to the trackers (new ones and existing ones). The error message I get is warning - cry...
Hyperbit
Oct 19, 2012Aspirant
can't install crypto 2.6
whats wrong?
2nd try with easy_install ends in same result
datengrab:/opt/pycrypto-2.6# python setup.py install
running install
running build
running build_py
running build_ext
running build_configure
building 'Crypto.PublicKey._fastmath' extension
cc -pthread -fno-strict-aliasing -fwrapv -Wall -Wstrict-prototypes -fPIC -std=c99 -O3 -fomit-frame-pointer -Isrc/ -I/usr/include/ -I/usr/include/python2.7 -c src/_fastmath.c -o build/temp.linux-padre-2.7/src/_fastmath.o
unable to execute cc: No such file or directory
error: command 'cc' failed with exit status 1
whats wrong?
datengrab:/c/datensammlung/pycrypto-2.6# easy_install http://pypi.python.org/packages/source/p/pycrypto/pycrypto-2.6.tar.gz#md5=88dad0a270d1fe83a39e0467a66a22bb
Downloading http://pypi.python.org/packages/source/p/pycrypto/pycrypto-2.6.tar.gz#md5=88dad0a270d1fe83a39e0467a66a22bb
Processing pycrypto-2.6.tar.gz
Running pycrypto-2.6/setup.py -q bdist_egg --dist-dir /tmp/easy_install-DUB9dV/pycrypto-2.6/egg-dist-tmp-sWHfqe
cc1: error: unrecognized option `-fwrapv'
error: Setup script exited with error: command 'cc' failed with exit status 1
