secret_rivals
Sep 16, 2009Aspirant
Torrentflux stopped connecting to torrents
I have been using Torrentflux for months with no problems at all. The other week my torrents stopped connecting to the trackers (new ones and existing ones). The error message I get is warning - cry...
Hyperbit
Oct 22, 2012Aspirant
datengrab:~# apt-get install python-dev
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python-dev: Depends: python (< 2.4) but 2.7.3~rc2-1.1rnx2 is to be installed
E: Broken packages
doesnt work..
i takes python from the readynasxtras site
