ssurba
Dec 03, 2015Guide
Transmission 2.84 for ReadyNAS OS 6
Hi all, you may download the latest versions of Transmission Bittorrent client for NETGEAR ReadyNAS storage systems from my GitHub: Transmission add-on package for ReadyNAS systems on ARM pr...
siddadav
Jan 04, 2016Aspirant
new to this, how do I install this? is there a guide?
DaneA
Jan 04, 2016NETGEAR Employee Retired
Hi siddadav,
Welcome to the community! :)
The latest version of the Transmission app for the ReadyNAS OS 6 is v3.00.8. You may double-check it here.
Here are the steps in installing app/s below:
a. On the web-GUI of your NAS, click on Apps tab.
b. Click on Available Apps then search for Transmission. You may click on the Refresh button located at the upper right corner of the Available Apps page to refresh the list of apps that are available.
c. Once you locate the Transmission app, click on install. Wait for a few moments.
d. After a few moments, click on Installed Apps to double-check that the Transmission app has been installed.
e. Click the Launch button to lauch the Transmission app.
Hope it helps.
DaneA
NETGEAR Community Team
