simp1
May 22, 2014Aspirant
Transmission 3.0.0.6
Hello, After updating Transmission to 3.0.0.6 everything worked fine. Then I started messing about. The settings.json file @ /Transmission/config seemed empty so I pasted the configuration to change...
simp1
when I opened it up with sublime text it was empty after the update.
then I pasted this in:
and then the error started appearing, then I deleted the pasted content and the error kept on coming.
was going to try it with { stuff here } but haven't got around to it yet.
Thanks
"rpc-authentication-required": true,
"rpc-username": "your-user-name",
"rpc-password": "your-password"
Thanks
