simp1
May 22, 2014Aspirant
Transmission 3.0.0.6
Hello, After updating Transmission to 3.0.0.6 everything worked fine. Then I started messing about. The settings.json file @ /Transmission/config seemed empty so I pasted the configuration to change...
simp1
As I said, after the update the settings file was empty for some reason.
It could have been my text editor playing tricks on me...
After I pasted the three lines in the error started appearing, if I remove them the error stays.
That's why I'm guessing my text editor didn't open the file properly on the first time.
hence the request for a dummy settings.json file :)
