simp1
May 22, 2014Aspirant
Transmission 3.0.0.6
Hello, After updating Transmission to 3.0.0.6 everything worked fine. Then I started messing about. The settings.json file @ /Transmission/config seemed empty so I pasted the configuration to change...
simp1
Thanks, got it working and was able to replicate the problem.
The whole ordeal comes from file permissions, I guess.
My text editor is denied access to settings.json, and it "opens the file" and shows it as an empty one.
but for some reason it is still able to overwrite it...
