cserba's avatar
cserba
Transmission 3.00.6 problems
Hi all.
I would like to ask for help from you all.
My transmission is acting very wired:
First - The installed version is shown in my admin page 3.00.6, but when I am in the application it is showin 2.82
Second - When I check available free space in my admin page it show 3.65TB but in the transmission 4.01TB
Third - The newly downloaded folders doesn't get date when it is finished in the downloaded folder.
The version of my Readynas 104 is 6.4.0
Printscreens:
1 Reply
  • I've been having the same problems since upgrade to latest version ReadyNAS OS 6.2.
    It seems to work intermittently ie. sometimes the page loads, but mostly not. Even if it loads, minutes later it will no longer be accessible. Strangely if I change the rpc-port to 9191, transmission loaded on 8181 like it always did. Bizarre..
    Transmission for ReadyNAS, version 3.00.6. settings.json pasted below, since the website doesn't seem to like any extensions I choose .json .txt etc...
    "alt-speed-down": 50,
    "alt-speed-enabled": false,
    "alt-speed-time-begin": 540,
    "alt-speed-time-day": 127,
    "alt-speed-time-enabled": false,
    "alt-speed-time-end": 1020,
    "alt-speed-up": 50,
    "bind-address-ipv4": "0.0.0.0",
    "bind-address-ipv6": "::",
    "blocklist-enabled": true,
    "blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
    "cache-size-mb": 4,
    "dht-enabled": true,
    "download-dir": "/data/media/Downloads",
    "download-queue-enabled": true,
    "download-queue-size": 5,
    "encryption": 1,
    "idle-seeding-limit": 30,
    "idle-seeding-limit-enabled": false,
    "incomplete-dir": "/data/Transmission/Incomplete",
    "incomplete-dir-enabled": true,
    "lpd-enabled": false,
    "message-level": 2,
    "peer-congestion-algorithm": "",
    "peer-id-ttl-hours": 6,
    "peer-limit-global": 240,
    "peer-limit-per-torrent": 60,
    "peer-port": 51413,
    "peer-port-random-high": 65535,
    "peer-port-random-low": 49152,
    "peer-port-random-on-start": false,
    "peer-socket-tos": "default",
    "pex-enabled": true,
    "port-forwarding-enabled": true,
    "preallocation": 1,
    "prefetch-enabled": 1,
    "queue-stalled-enabled": true,
    "queue-stalled-minutes": 30,
    "ratio-limit": 2,
    "ratio-limit-enabled": false,
    "rename-partial-files": true,
    "rpc-authentication-required": true,
    "rpc-bind-address": "0.0.0.0",
    "rpc-enabled": true,
    "rpc-password": "{14ee7acbbe547e5e13ff24e545e87522c9febb71gRlpx/cm",
    "rpc-port": 8181,
    "rpc-url": "/transmission/",
    "rpc-username": "admin",
    "rpc-whitelist": "*",
    "rpc-whitelist-enabled": true,
    "scrape-paused-torrents-enabled": true,
    "script-torrent-done-enabled": false,
    "script-torrent-done-filename": "",
    "seed-queue-enabled": false,
    "seed-queue-size": 10,
    "speed-limit-down": 100,
    "speed-limit-down-enabled": false,
    "speed-limit-up": 100,
    "speed-limit-up-enabled": false,
    "start-added-torrents": true,
    "trash-original-torrent-files": false,
    "umask": 18,
    "upload-slots-per-torrent": 14,
    "utp-enabled": true
ProSupport for Business
