brock_gonad
Mar 28, 2018Aspirant
Transmission NT on RN6, can't add torrent via Remote GUI
Hi Guys - I'm bashing my head against the wall trying to get Transmission Remote GUI set up after migrating from OS4 to OS6. I've got Transmission NT installed, and it's working fine. Where I'm havin...
mdgm-ntgr
Mar 28, 2018NETGEAR Employee Retired
Did you download the logs and look for a more verbose error message?
- brock_gonadMar 29, 2018Aspirant
About the only thing I see in the HTTP log is a lot of this;
Mar 29 17:10:58 ReadyNAS apache2[6201]: [error] (70007)The timeout specified has expired: proxy: prefetch request body failed to 127.0.0.1:9201 (127.0.0.1) from 192.168.60.10 ()
Are there any other logs that may shed more light?
- StephenBMar 30, 2018Guru - Experienced User
Try looking in \\nas-ip-address\data\.apps\nastools-transmission\rpc with NAS admin credentials via windows explorer.
If your volume name isn't data, then change the path to include your volume name.
- brock_gonadMar 30, 2018Aspirant
Thanks for that. Here's how Windows sees the mounts;
And here's how my volumes are set up as seen by WinSCP. Not using X-Raid. Two hard drives, each their own volume. I've got my shares on the WD_Blue_6TB volume. I'm trying to save into WD_6TB_Blue/Media/Downloads. As you can see above, it's weird that I'm able to start torrents to this folder just fine, but only when I do it from the web remote, but not the Remote GUI app.
Thanks again for any help.
