atai1960
Apr 24, 2016Aspirant
Transmission permission denied on model 104
Hi, I have a problem with Transmission; everything start when I changed the Internet Provider. I changed the DNS but when I start the download after few mb I receive the error: permission denied...
BrianL2
Apr 25, 2016NETGEAR Employee Retired
Hi atai1960,
Which DNS address or server have you added to your system? Make it 8.8.8.8 or your router gateway (IP) address and see if fixes the problem. Also, tell us where have you downloaded the transmission add-on (if it's on the get apps page or the available apps tab in the UI).
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
atai1960
Apr 25, 2016Aspirant
Hi BrianL,
Insert 8.8.8.8 on DNS address was the first thing done following another answer that I have seen here for the same problem. But di not works. I have downloaded the transmission add-on from the app page.
Thanks
- BrianL2Apr 25, 2016NETGEAR Employee Retired
Hi atai1960,
Let's seek assistance from super_poussin and hear suggestions from other community members if they have experienced the same.
Kind regards,
BrianL
NETGEAR Community Team- atai1960Apr 29, 2016Aspirant
Any news about?
I am looking for a program that allow me to download torrent file without use a computer; Transmission was very good for this.
Thanks
- kohdeeApr 29, 2016Administrator
Can you show where it says permission denied? You probably need to open up the share to read/write permissions more if you have a write issue. Check your shares' permissions.
