northernlights
Jun 07, 2016Aspirant
Transmission torrent client problem
Hello, I recently bought the NAS device and after transmission install when I start it up and try to download the torrent file there was an error related to permission. Can you please help me wit...
- Jun 09, 2016
Hello northernlights,
I'm glad it works now.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.Please feel free to post any comments, suggestions and question, we appreciate your contribution to the community!
JennC
Jun 08, 2016NETGEAR Employee Retired
Are you getting the same error message when downloading other torrents? Or from other to torrent site?
I have tried this just now and it seems to work with no errors or issue.
Welcome to the community!
northernlights
Jun 08, 2016Aspirant
Hello,
I tried other torrents from different torrent sites and all are giving me the same error. I even tried to create new volumes and try installing transmission from scratch and same problem again. Transmission client on my router is working fine even with the same torrent file.
Thanks,
- JennCJun 08, 2016NETGEAR Employee Retired
You are the same person in the other discussion, this may have something to do with the destination folder.
- northernlightsJun 09, 2016Aspirant
Hello JennC,
yesterday I figured out the problem I had with Transmission. After I did the factory restore and installed Transmission again it worked. Than I noticed the volume name is different than what I was using it before. Now I just use the default name for my volume and it works no problem.
Thanks for the support,
- JennCJun 09, 2016NETGEAR Employee Retired
