northernlights
Jun 07, 2016Aspirant
Transmission torrent client problem
Hello, I recently bought the NAS device and after transmission install when I start it up and try to download the torrent file there was an error related to permission. Can you please help me wit...
- Jun 09, 2016
Hello northernlights,
I'm glad it works now.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.Please feel free to post any comments, suggestions and question, we appreciate your contribution to the community!
northernlights
Jun 09, 2016Aspirant
Hello JennC,
yesterday I figured out the problem I had with Transmission. After I did the factory restore and installed Transmission again it worked. Than I noticed the volume name is different than what I was using it before. Now I just use the default name for my volume and it works no problem.
Thanks for the support,
JennC
Jun 09, 2016NETGEAR Employee Retired
