horim80's avatar
horim80
Guide
Aug 31, 2015
Transmission torrent done email notification on OS6
on OS4 NAS such as Pro2, Tranmission send a mail when a torrent is done. It was very good function. but it seems not work on OS6 transmission app. Does anyone make it work on OS6 as well?
  • horim80's avatar
    Sep 06, 2015
    I solved it by myself.
    Here is the steps
    1. turn off the Transmission app on Web-GUI.
    2. edit :  nano /etc/init.d/transmission
    3. find USERNAME=guest:guest and change it to root:root.
    4. create a email alert script :  nano /data/Transmission/config/email_alert
    #!/bin/sh
    NAIL=/usr/bin/nail
    SMTP_SERVER=smtp.orange.fr
    SUBJECT="Torrent Done!"
    if [ -f /etc/frontview/alert.conf ]; then
     EmailTo=`/bin/grep "email" /etc/frontview/alert.conf | /usr/bin/awk -F '!!' '{ print $2 }' | /usr/bin/awk -F ',' '{ print $1 " " $2 " " $3 }'`
    else
     EmailTo=`/bin/grep "email" /frontview/conf/alert.conf | /usr/bin/awk -F '!!' '{ print $2 }' | /usr/bin/awk -F ',' '{ print $1 " " $2 " " $3 }'`
    fi
        if [ "$(readlink `which sendmail`)" = "/usr/bin/msmtp" ]; then
        EmailFrom=`/bin/grep '^from' /etc/msmtprc | /usr/bin/cut -f2 -d' '`
        else
        EmailFrom=`/bin/echo $EmailTo | awk '{ print $1 }'`
        fi
        echo "From:$EmailFrom To:$EmailTo"
        # Create the email message
        EmailFile=/tmp/tmp_email.txt
        if [ -f "$EmailFile" ]; then
        rm -f $EmailFile
        fi
        touch $EmailFile
        # Create the message headers
        echo "Date: `date -R`" >> $EmailFile
        echo "From: $EmailFrom" >> $EmailFile
        echo "To: $EmailTo" >> $EmailFile
        echo "Subject:Torrent Done!" >> $EmailFile
        echo "MIME-Version: 1.0" >> $EmailFile
        echo "Content-Type: text/plain; charset=ISO-8859-1" >> $EmailFile
        echo "" >> $EmailFile
        # Create the message body
        /bin/echo "Hostname: $(hostname)" >> $EmailFile
        /bin/echo "Transmission finished downloading \"$TR_TORRENT_NAME\" on $TR_TIME_LOCALTIME" >> $EmailFile
        /bin/echo "" >> $EmailFile
        /bin/echo "----------------------------------------------------------------------" >> $EmailFile
        /bin/echo "Your add-ons developer Super-Poussin" >> $EmailFile
        /bin/cat $EmailFile |/usr/sbin/sendmail -f $EmailFrom $EmailTo
        #$NAIL -v -S from="$EmailFrom" -S smtp -s "$SUBJECT" -S smtp=$SMTP_SERVER "$EmailTo" < $EmailFile
        rm -f $EmailFile
    5. change file permission :  chmod 755 /data/Transmission/config/email_alert
    6. edit setting file :  nano /data/Transmission/config/settings.json
    7. change a value as below :
    "script-torrent-done-enabled": true,
    "script-torrent-done-filename": "/data/Transmission/config/email_alert",
    8. Turn on Transmission app on WEB-GUI.
    You will receive alert email when torrent download is done.
ProSupport for Business
