horim80
Aug 31, 2015Guide
Transmission torrent done email notification on OS6
on OS4 NAS such as Pro2, Tranmission send a mail when a torrent is done. It was very good function. but it seems not work on OS6 transmission app. Does anyone make it work on OS6 as well?
- Sep 06, 2015
I solved it by myself.
Here is the steps
1. turn off the Transmission app on Web-GUI.
2. edit : nano /etc/init.d/transmission
3. find USERNAME=guest:guest and change it to root:root.
4. create a email alert script : nano /data/Transmission/config/email_alert
#!/bin/sh NAIL=/usr/bin/nail SMTP_SERVER=smtp.orange.fr SUBJECT="Torrent Done!" if [ -f /etc/frontview/alert.conf ]; then EmailTo=`/bin/grep "email" /etc/frontview/alert.conf | /usr/bin/awk -F '!!' '{ print $2 }' | /usr/bin/awk -F ',' '{ print $1 " " $2 " " $3 }'` else EmailTo=`/bin/grep "email" /frontview/conf/alert.conf | /usr/bin/awk -F '!!' '{ print $2 }' | /usr/bin/awk -F ',' '{ print $1 " " $2 " " $3 }'` fi if [ "$(readlink `which sendmail`)" = "/usr/bin/msmtp" ]; then EmailFrom=`/bin/grep '^from' /etc/msmtprc | /usr/bin/cut -f2 -d' '` else EmailFrom=`/bin/echo $EmailTo | awk '{ print $1 }'` fi echo "From:$EmailFrom To:$EmailTo" # Create the email message EmailFile=/tmp/tmp_email.txt if [ -f "$EmailFile" ]; then rm -f $EmailFile fi touch $EmailFile # Create the message headers echo "Date: `date -R`" >> $EmailFile echo "From: $EmailFrom" >> $EmailFile echo "To: $EmailTo" >> $EmailFile echo "Subject:Torrent Done!" >> $EmailFile echo "MIME-Version: 1.0" >> $EmailFile echo "Content-Type: text/plain; charset=ISO-8859-1" >> $EmailFile echo "" >> $EmailFile # Create the message body /bin/echo "Hostname: $(hostname)" >> $EmailFile /bin/echo "Transmission finished downloading \"$TR_TORRENT_NAME\" on $TR_TIME_LOCALTIME" >> $EmailFile /bin/echo "" >> $EmailFile /bin/echo "----------------------------------------------------------------------" >> $EmailFile /bin/echo "Your add-ons developer Super-Poussin" >> $EmailFile /bin/cat $EmailFile |/usr/sbin/sendmail -f $EmailFrom $EmailTo #$NAIL -v -S from="$EmailFrom" -S smtp -s "$SUBJECT" -S smtp=$SMTP_SERVER "$EmailTo" < $EmailFile rm -f $EmailFile5. change file permission : chmod 755 /data/Transmission/config/email_alert
6. edit setting file : nano /data/Transmission/config/settings.json
7. change a value as below :
"script-torrent-done-enabled": true, "script-torrent-done-filename": "/data/Transmission/config/email_alert",
8. Turn on Transmission app on WEB-GUI.
You will receive alert email when torrent download is done.
horim80
Sep 06, 2015Guide
Here is the steps
#!/bin/sh
NAIL=/usr/bin/nail
else
fi
else
fi
rm -f $EmailFile
fi
touch $EmailFile
