Rembo
Nov 16, 2015Aspirant
Transmission torrent not starting since RAIDiator 4.2.28
SInce I've upgraded my ReadyNAS Ultra 4 Plus to RAIDiator 4.2.28 last weekend the torrents are not starting anymore. I have tried to reinstall Transmission 2.82 and to downgrade to RAIDiator 4.2.27 ...
Nov 16, 2015Guru - Experienced User
Is the NAS using dhcp or a static address?
If dhcp- were you forwarding ports for transmission in the router? If so, did the local address change?
if static - you might want to check that your subnet and dns settings are still correct.
Rembo
I'm using static DHCP and my DNS are looking like that with IPv6 first:
RNU4P:~# cat /etc/resolv.conf
nameserver 2001:4860:4860::8888
nameserver 2001:4860:4860::8844
nameserver 192.168.1.1
nameserver 213.221.144.240
nameserver 213.221.143.240
RNU4P:~#
As on my Mac it's IPv4 first:
- StephenBNov 17, 2015Guru - Experienced User
Does anything change if you disable IPv6 on the NAS?
- RemboNov 17, 2015Aspirant
I've tried IPv4 only and it's the same, but setting the port on the NAS from 51413 to 61200 like it's on my Mac made it work.
Both ports are normally not forwarded on my router, even opening 51413 (and testing it from outside) didn't improve anything, I don't know why 51413 stopped working after years.
Anyway, thanks for helping me.
Further testing, it seems that it's activating DHT to find more peers who did the job, before I had only PEX activated.
