fireaza
Sep 03, 2016Follower
Trying to get Transmission Remote GUI working on ReadyNAS 104
I'm trying to get Transmission working on my new ReadyNAS 104 so I can retire my Raspberry Pi torrent box. On that, I used Deluge, so Transmission is new to me. I've got Transmission NT downloaded an...
NAStools
Sep 06, 2016Luminary
My Transmission package Transmission NT v2.92-nt1 is separate from Poussin's transmission v3.00.8.
Anyway, the article you linked and any editing of settings.json (which is located in /apps/nastools-transmission/etc) should not be necessary.
Here are the settings you need:
User name/Password: You can either use the ReadyNAS admin login, or add a user to the nastools-transmission group and use that login.
