fireaza
Sep 03, 2016Follower
Trying to get Transmission Remote GUI working on ReadyNAS 104
I'm trying to get Transmission working on my new ReadyNAS 104 so I can retire my Raspberry Pi torrent box. On that, I used Deluge, so Transmission is new to me. I've got Transmission NT downloaded an...
ChunkySocks
Feb 07, 2017Guide
Hi NAStools,
Thanks for that pic of the settings to use with Transmission Remote GUI.
However, I'm trying to use it to connect with Transmission NT which is running on my Ultra 2 with OS6.6.1 when I'm not at home and I can't find info on what the correct path is to input into Remote host:. Currently I have [My home IP]/ReadyNAS_name with the other fields being identical to what you have in your picture.
Thanks in advance for any help.
ChunkySocks
Feb 08, 2017Guide
To update - scrub my last post, connecting to my ReadyNAS using Transmission Remote GUI outside of my home network isn't really connected to this thread, I'll get round to posting a new thread about that separately.
I did try to connect using Transmission Remote GUI over my LAN using these instructions and, at first, it didn't work. I tried using the name of my ReadyNAS in the remote host then replaced it with the IP address (192.168.0.x) on my home network but no joy. Then, for some reason, I just re-typed the IP into the Remote host field and it suddenly sprang to life and Transmission Remote GUI offers so many more options than the web interface so all good.
- mkliaoFeb 22, 2017Aspirant
I need instruction to use Transmission Remote GUI outside of my home network with Transmission NT by NASTools.
Does it work with ReadyCloud? That's the only remote access I have for my RN102. Thanks.
