iamthemitch
Nov 28, 2017Star
Unable to compile ReadyNASOS 6.9.0 kernel
Hi, Initial topic has been closed (https://community.netgear.com/t5/Community-Add-ons/Missing-GPL-Source-for-ReadyNAS-6-8-1/m-p/1407561), but we are not able to compile ReadyNASOS 6.9.0 kernel. LD...
mdgm-ntgr
Nov 28, 2017NETGEAR Employee Retired
Did you compile previous kernels successfully?
- iamthemitchNov 28, 2017Star
Yes
Compile was fine on 6.8.0 and 6.8.1
jpearn has been able to compile 6.9.0 by replacing fs/cifs with the one from 6.8.1.
I didn't had the chance to try this workarounfd for now.- SkywalkerNov 28, 2017NETGEAR Expert
$ diff -u fs/cifs/connect.c.orig fs/cifs/connect.c --- fs/cifs/connect.c.orig 2017-10-28 12:34:28.328786905 +0200 +++ fs/cifs/connect.c 2017-10-28 12:35:38.069563894 +0200 @@ -507,7 +507,7 @@ server->tcpStatus == CifsNeedNegotiate) && time_after(jiffies, server->lstrp + 2 * SMB_ECHO_INTERVAL)) { cifs_dbg(VFS, "Server %s has not responded in %lu seconds. Reconnecting...\n", - server->hostname, (2 * server->echo_interval) / HZ); + server->hostname, (2 * SMB_ECHO_INTERVAL) / HZ); cifs_reconnect(server); wake_up(&server->response_q); return true;- iamthemitchNov 28, 2017Star
:smileylol: at least, the error match the diff.
1/ the workaroud sounds safe
2/ shouldn't be to hard to correct the 6.9.0 sources zip file
- Mar 10, 2018Retired_Member
