iamthemitch
Nov 28, 2017Star
Unable to compile ReadyNASOS 6.9.0 kernel
Hi, Initial topic has been closed (https://community.netgear.com/t5/Community-Add-ons/Missing-GPL-Source-for-ReadyNAS-6-8-1/m-p/1407561), but we are not able to compile ReadyNASOS 6.9.0 kernel. LD...
mdgm-ntgr
Nov 28, 2017NETGEAR Employee Retired
Did you compile previous kernels successfully?
iamthemitch
Nov 28, 2017Star
Yes
Compile was fine on 6.8.0 and 6.8.1
jpearn has been able to compile 6.9.0 by replacing fs/cifs with the one from 6.8.1.
I didn't had the chance to try this workarounfd for now.
- SkywalkerNov 28, 2017NETGEAR Expert
$ diff -u fs/cifs/connect.c.orig fs/cifs/connect.c --- fs/cifs/connect.c.orig 2017-10-28 12:34:28.328786905 +0200 +++ fs/cifs/connect.c 2017-10-28 12:35:38.069563894 +0200 @@ -507,7 +507,7 @@ server->tcpStatus == CifsNeedNegotiate) && time_after(jiffies, server->lstrp + 2 * SMB_ECHO_INTERVAL)) { cifs_dbg(VFS, "Server %s has not responded in %lu seconds. Reconnecting...\n", - server->hostname, (2 * server->echo_interval) / HZ); + server->hostname, (2 * SMB_ECHO_INTERVAL) / HZ); cifs_reconnect(server); wake_up(&server->response_q); return true;- iamthemitchNov 28, 2017Star
:smileylol: at least, the error match the diff.
1/ the workaroud sounds safe
2/ shouldn't be to hard to correct the 6.9.0 sources zip file
- Mar 10, 2018Retired_Member
