snooker
Mar 13, 2017Star
UniFi Controller on ReadyNAS
Recently I ran into some trouble (All snapshots disappeared + no new snapshots possible) when I tried to install the UniFi Controller on my ReadyNAS. After I have overcome two small obstacles it wor...
- Jun 07, 2017
The guide at the top of this thread is a little bit outdated (Oracle Java is no longer in the repository), so here ist a small update:
I would like to share here the solution that works for me on OS 6.7.4 (x86):
The UniFi Controller needs Java, so we have to install that first.First we check if Java is already installed (it is not part of the OS, but it may be installed together with some apps):
java --version
If we get back "-bash: java: command not found", Java is not installed on the ReadyNAS, so we have to install it, if we get back a Version String, we can skip the Java installation:
apt-get update apt-get install install openjdk-7-jdk
Then we have to add the Ubiquiti repository and the key:
echo "deb http://www.ubnt.com/downloads/unifi/debian unifi5 ubiquiti" | tee /etc/apt/sources.list.d/100-ubnt.list apt-key adv --keyserver keyserver.ubuntu.com --recv C0A52C50
After that, we can install the UniFi controller:apt-get update
apt-get install unifi
I copied the systemd service file, to /etc/systemd/system in the case that I have to make some tweaks:cp -p /lib/systemd/system/unifi.service /etc/systemd/system
After the install there is the problem, that the software is installed unter /var/lib on the OS partition and the included MongoDB will need 3GB under /var/lib/unifi/db, which is not available.
So we have to move the UniFi controller to a place with sufficient space, e.g. /apps:cd /var/lib mv unifi /apps ln -s /apps/unifi unifi
As the last step we now can update the logrotate configuration to rotate also the Unifi logs:
bash -c 'cat >> /etc/logrotate.d/unifi << EOF /var/log/unifi/*.log { rotate 5 daily missingok notifempty compress delaycompress copytruncate } EOF'And now the Unifi controller should start with:
systemctl start unifi.service
To access the User Interface of the controller navigate to:https://<IP_of_your_ReadyNAS>:8443
If it is not working, it might be worth to look into the logs in /var/log/unifi.
Possible problems:- Unifi needs the ports 3478, 8080, 8443, 8843, 8880, 8881, 8882 and 27117. If other Apps use these ports you have to change the settting of UniFi.
enkrypt3d
Jun 07, 2017Tutor
Already got it working since java is already installed all I had to do is skip the intall of java... works great!
Here is the latest beta package for Unifi controller 5.6.7:
https://www.ubnt.com/downloads/unifi/5.6.7-63ab9a7965/unifi_sysvinit_all.deb
So much better than running on my PC!
snooker
Jun 07, 2017Star
Good to hear, that the Unifi Controller now runs smoothly at your device.
I checked it now on my spare ReadyNAS which is running 6.7.4:
- On my device no Java was installed with 6.7.4 (the command "java" was not found at the command line). Maybe your Java was installed piggybacked with another App?
- As you reported, Oracle Java was not in the apt repository.
- But using "apt-get install openjdk-7-jdk" to install the openjdk worked fine. And the Unifi Controlled worked also with the openjdk.
- enkrypt3dJun 07, 2017Tutor
I may have installed java before as this Pro 4 was upgraded from OS4 to OS6... so it may have some bits left over......
- StephenBJun 07, 2017Guru - Experienced User
The OS6 migration would have wiped everything.
ah yea you're right - not sure how java got installed......
root@NAS:~# java -version
java version "1.7.0_131"
OpenJDK Runtime Environment (IcedTea 2.6.9) (7u131-2.6.9-2~deb8u1)
OpenJDK 64-Bit Server VM (build 24.131-b00, mixed mode)As long as it works I'm fine with it! It may have been installed by one of my addons..
