Retired_Member
Mar 10, 2018uTorrent 3.3.30470 on ReadyNASOS 6.9.2?
I had this app installed from way back, never really used it so I tried to uninstall it but it failed. I tried manual re-install (upload) to do a clean un-install, but failed. Now the WebGUI h...
- Mar 27, 2018
There was a change in the reprove process on the ReadyNAS and my app was not able to handle it gracefully on the newer firmware. I have updated the app to fix the remove issue that you might be encountering.
https://github.com/Mhynlo/rn-utorrent/releases/tag/3.3.30470-ml0
Try updating the app and removing it again.
Retired_Member
Mar 23, 2018I'll try another browser and see if that works - I have poor access luck using other pc's/browsers with the Admin page (just usually sticks at the loading screen).
I believe the Admin Page needs a clean-up (app validation, and removal) since it appears the app may be un-installed from the system, just not removed from Frontview - either that, or its disabled/off, and I can't turn it on/off (grey'ed on/off button) since it won't even run. I installed an earlier version which worked, then tried to uninstall that, but it also failed (now I have 2 broken versions lol).
I'll wait for the next OS upgrade after 6.9.3 before trying, since 6.9.3 doesn't appear to be working well with this RN316 atm.
Mhynlo
Mar 27, 2018Luminary
- jpass022May 12, 2018Luminary
Thanks Mhynlo,
This cleaned up my uTorrent uninstall...
