EJBeffel3
Sep 18, 2020Aspirant
WARNING OS X Catalina Time Machine Sept 2020 update incompatible with 6.10.3 firmware
After two weeks working with ReadyNAS paid support, we've confirmed that the latest OS X update to Catalina appears to be incompatible with the latest 6.10.3 firmware. I have four Mac devices: MacPro...
- Sep 28, 2020
When you say "Catalina", which update? I think 10.15.7 has gone GA now, but only just recnetly. So were you running 10.15.7 beta, or are you referring to some other update? I've had an MBP running Catalina backing up to ROS 6.10.3 for a while now.
But if this behavior is confirmed to be happening on 10.15.7 then that should be an explicit warning for anyone running 10.15.6 not to upgrade yet.
I've not pulled the trigger on my macOS update yet, so I'm curious to hear about the specifics.
Sep 19, 2020Guru - Experienced User
I think you meant 6.10.3 fimware. Do you want that corrected in your post?
- EJBeffel3Sep 19, 2020Aspirant
You're exactly right. 6.10.3, not 6.3. Thank you.
- StephenBSep 19, 2020Guru - Experienced User
I edited the title and text in your original post.
- Marc_VSep 24, 2020NETGEAR Employee Retired
Welcome to the Community!
May I ask for the case number you had with Support? As I may be checking on a different case. The last update I got was that they didn't got the issue reproduced.
Was the case escalated already? If this is a bug then we can expect for a fix once the case has been submitted.
