EJBeffel3
Sep 18, 2020Aspirant
WARNING OS X Catalina Time Machine Sept 2020 update incompatible with 6.10.3 firmware
After two weeks working with ReadyNAS paid support, we've confirmed that the latest OS X update to Catalina appears to be incompatible with the latest 6.10.3 firmware. I have four Mac devices: MacPro...
- Sep 28, 2020
When you say "Catalina", which update? I think 10.15.7 has gone GA now, but only just recnetly. So were you running 10.15.7 beta, or are you referring to some other update? I've had an MBP running Catalina backing up to ROS 6.10.3 for a while now.
But if this behavior is confirmed to be happening on 10.15.7 then that should be an explicit warning for anyone running 10.15.6 not to upgrade yet.
I've not pulled the trigger on my macOS update yet, so I'm curious to hear about the specifics.
