EJBeffel3
Sep 18, 2020Aspirant
WARNING OS X Catalina Time Machine Sept 2020 update incompatible with 6.10.3 firmware
After two weeks working with ReadyNAS paid support, we've confirmed that the latest OS X update to Catalina appears to be incompatible with the latest 6.10.3 firmware. I have four Mac devices: MacPro...
- Sep 28, 2020
When you say "Catalina", which update? I think 10.15.7 has gone GA now, but only just recnetly. So were you running 10.15.7 beta, or are you referring to some other update? I've had an MBP running Catalina backing up to ROS 6.10.3 for a while now.
But if this behavior is confirmed to be happening on 10.15.7 then that should be an explicit warning for anyone running 10.15.6 not to upgrade yet.
I've not pulled the trigger on my macOS update yet, so I'm curious to hear about the specifics.
btaroli
Sep 28, 2020Prodigy
- EJBeffel3Sep 30, 2020Aspirant
Unwarning from Ernie: The incompatability that I encountered turned out to be the 424 going into read only mode. There was corruption in the file structure. I had a second 424 for offsite backup. A factory reset, rebuild of Time Machines and restore of shares fixed the problem. It remains unclear what caused the file structure corruption. Northern California has had power outages and an outage or power transient may have done it. I am now successfully running Time Machine for three Macs on the restored ReadyNAS.
Thanks to support staff for confirming the file structure corruption and walking me through the rebuild. Best regards, Ernie Beffel
