viliusp
Mar 04, 2016Aspirant
What happened to Transmission after 6.4.2 update?
Hey guys, have anyone experienced this that after the Firmware upgrade the Transmission app just fails to function properly? It is responding, I can add/remove torrent files there, but the appli...
- Mar 05, 2016
Hi all,
thanks for the replies, it turns out I fixed it with the simplest trick in the book --- re-install of the app. Turns out that re-config of the settings.json helped.
Now as for the update, here's what I've done:
- trashed my current Transmission app.
- I've checked here: transmission_2.90-1_armel.deb and downloaded the newest 2.9 version
- Installed it on the NAS. There's a catch, once you upload the app and the notification center tells you that transmission is installed, it isn't listed in the app dashboard.
- I uploaded the transmissionr6_3.00.8_all.deb
- In the Transmission site clicking Settings > About shows 2.9
Maybe you would wonder why you need two different install files for one app, I was wondering too.
Anyway, it works, and the app is updated. Everybody's happy.
Cheers
