viliusp
Mar 04, 2016Aspirant
What happened to Transmission after 6.4.2 update?
Hey guys, have anyone experienced this that after the Firmware upgrade the Transmission app just fails to function properly? It is responding, I can add/remove torrent files there, but the appli...
- Mar 05, 2016
Hi all,
thanks for the replies, it turns out I fixed it with the simplest trick in the book --- re-install of the app. Turns out that re-config of the settings.json helped.
Now as for the update, here's what I've done:
- trashed my current Transmission app.
- I've checked here: transmission_2.90-1_armel.deb and downloaded the newest 2.9 version
- Installed it on the NAS. There's a catch, once you upload the app and the notification center tells you that transmission is installed, it isn't listed in the app dashboard.
- I uploaded the transmissionr6_3.00.8_all.deb
- In the Transmission site clicking Settings > About shows 2.9
Maybe you would wonder why you need two different install files for one app, I was wondering too.
Anyway, it works, and the app is updated. Everybody's happy.
Cheers
viliusp
Mar 05, 2016Aspirant
Hi all,
Cheers
super_poussin
Mar 07, 2016Virtuoso
when you install an app on the nas it's a .deb file , this deb file can't call apt-get to install another deb package so the package for transmission is cut in too
One package for the interface on the nas
One package for transmission it-self
and only th e transmission package change each time transmission change,
To have only one package I need to submit trnasmission binary package to Netgear, each time I do a change and it takes a long time so I decide to no more submit packages to Netgear and rather provide packages on the community dropbox I create.
- ChiffaNeMar 30, 2016Tutor
Hi Super!
Works superb, thank you so much for all your work.
I have a question - would it be possible to create some kind of a simple web-gui for automatic to manage the feeds and filters? It's such a pain to edit everything in text.
Thank you in advance!
