ChunkySocks
Feb 01, 2017Guide
What's the difference between Transmission NT and Transmission for Readynas?
I have just sucessfully updated my legacy ReadyNAS Ultra 2 to OS6.6.1 and am starting to move files back onto it as well as attempting to get it working much as it did on RAIDiator 4.2.30. Lookin...
- Feb 01, 2017
ChunkySocks wrote:
Looking at the apps available to install on OS6, what's the difference between NAStools' Transmission NT and Poussin's Transmission for Readynas as I inadvertently installed both and couldn't tell the difference.
NAStool's app is newer - I suggest you use his and uninstall the older one from Poussin.
Feb 01, 2017Guru - Experienced User
ChunkySocks
Feb 01, 2017Guide
Have actually done a factory reset as I was having problems with the Permission denied error and trying to troubleshoot it (for another thread if I can't work it out!) but what about µTorrent or is NAStools the most updated torrent client there is atm?
- mdgm-ntgrFeb 01, 2017NETGEAR Employee Retired
The NASTools one would be the one to go with.
- ChunkySocksFeb 02, 2017Guide
Thanks for both of your replies.
Installed and working well.
