tmm1
Nov 30, 2016Aspirant
Writing my own Add-On: .deb installs and service running, but won't show in GUI
I've written a very simple add-on based on the samples in the SDK. The .deb file installs successfully onto the device, and the service is running (after invoking `rn_nml -S` in postinst. But it does...
- Dec 01, 2016
Alright, I tested out channels-dvr_1.0.5_all.deb on a fresh 6.6.0 VM. Looks good from a quick glance:
If you enable System > Settings > Support > Secure Diagnostic Mode and give me the port I can poke around on your system and see what's going on.
tmm1
Dec 01, 2016Aspirant
From the UI. I verified that the .localapp file is in place.
tmm1
Here's the .deb if you want to try installing or extracting it: http://channels-dvr.s3.amazonaws.com/netgear/channels-dvr_1.0.5_all.deb
