tmm1's avatar
tmm1
Writing my own Add-On: .deb installs and service running, but won't show in GUI
I've written a very simple add-on based on the samples in the SDK. The .deb file installs successfully onto the device, and the service is running (after invoking `rn_nml -S` in postinst. But it does...
  • siigna's avatar
    siigna
    Dec 01, 2016
    Alright, I tested out channels-dvr_1.0.5_all.deb on a fresh 6.6.0 VM.  Looks good from a quick glance:
    If you enable System > Settings > Support > Secure Diagnostic Mode and give me the port I can poke around on your system and see what's going on.
ProSupport for Business
