antefil
Apr 28, 2023Aspirant
102
After updating the firmware, the device does not start. I can't connect to it because there is no ip address. the radar does not see the device. The disc 1 and disc 2 indicators are not lit. Help
- May 05, 2023
antefil wrote:
1) I downloaded the firmware
Totally wrong firmware for a different ReadyNAS model. You should be using this:
Apr 28, 2023Guru - Experienced User
What firmware were you running before you did the update? Is it possible that you were running 6.3.x or earlier?
Also, try removing the disks (NAS powered down), and then power up the diskless. Do you see any LEDs (including power)? Does RAIDar find the NAS with no disks inserted?
antefil
May 01, 2023Aspirant
First there was the firmware Software Version 6.1.6. I have upgraded to 6.1.7 after which 6.1.8 after which 6.1.9.
After successful updates, I launched Software Version 6.10.8. The device rebooted and no longer turned on.
The Power bulb lights up and Acta. Without disks, only the power button
