antefil
Apr 28, 2023Aspirant
102
After updating the firmware, the device does not start. I can't connect to it because there is no ip address. the radar does not see the device. The disc 1 and disc 2 indicators are not lit. Help
- May 05, 2023
antefil wrote:
1) I downloaded the firmware
Totally wrong firmware for a different ReadyNAS model. You should be using this:
antefil
May 04, 2023Aspirant
2) Instruction manual
https://kb.netgear.com/21400/RAIDiator-4-1-USB-Recovery-Tool
3) Now I will try to install
Checked:
the power button and the backup button are flashing . The USB light bulb does not blink
