Carlo71
Mar 29, 2023Aspirant
12tb Ironwolf in ReadyNAS RN314
Hello, I am replacing my ageing 3tb Barracuda hard drive with a Seagate Ironwolf Pro 12tb drive, the status on the drive is currently saying "degraded" and the drive has not yet shown up on the Netg...
Carlo71
Might i need to format the drive in a particular fashion?
(I was under the impression that the NAS did this automatically)
Sandshark
Mar 29, 2023Sensei
You want it unformatted. Did you try the refresh button? Is there an entry in the log?
- Carlo71Mar 29, 2023Aspirant
I have refreshed the browser - no joy.
It isn't a new hard drive...anything I need to do?
This is what the log says.
OK, looks like mystery solved...think the hard drive is U/S...tried to mount it in an external caddy and reformat using NTFS, but it won't even mount and I can hear a repeating "eeee" noise coming from it...looks like its a return to sender job. Swapped it out for the HDD that arrived afterwards and that mounted and is rebuilding the database straight away.
- StephenBMar 30, 2023Guru - Experienced User
Definitely a dead drive. I usually test mine in a PC before I add them to the NAS - using Seatools for Ironwolf. I run the full non-destructive read test, and follow that up with the full erase test - because I've purchased some drives that failed one of these tests, and passed the other. It takes a couple of days for a 12 TB drive, but I'd rather find issues before I put my drives into the NAS.
Note you won't see any capacity increase in your volume until you upgrade another drive to 12 TB. Then you'd end up with 18 TB (~16.37 TiB) of space.
As an aside - you don't need to use RAIDar to get to the NAS admin pages. You can just access the web ui from the browser - either https://nas-name/admin or https://nas-ip-address/admin will get you there.
