supracom
Jul 26, 2011Follower
1GB Memory for ReadyNAS NV
Hello, I searched extensively for a compatible DIMM for my ReadyNAS NV to upgrade it to 1GB. I already ordered a wrong module by guessing what type I needed so I would like to have a type-nr from s...
Jemini
Oct 13, 2011Aspirant
claykin wrote: NV/NV+ be spec uses PC2700. This module will work. http://www.crucial.com/store/partspecs. ... T12864X335
If your unit came with PC3200 CL3 then this one should work as well. Not sure it will provide any advantage as I think the NV/NV+ motherboard will still be limited to PC2700 speed.
http://www.crucial.com/store/partspecs. ... T12864X40B
Is that ture? Or I can just buy a DDR 333 instead of a DDR400
