supracom
Jul 26, 2011Follower
1GB Memory for ReadyNAS NV
Hello, I searched extensively for a compatible DIMM for my ReadyNAS NV to upgrade it to 1GB. I already ordered a wrong module by guessing what type I needed so I would like to have a type-nr from s...
B1234
Nov 09, 2011Aspirant
BikeHelmet wrote: If you're in Canada (or the US) this stuff seems to be compatible:
http://www.ncix.com/products/?sku=31402&promoid=1292
http://www.bestdirect.ca/products/177984/PSD1G33316S/Patriot/
Passed three rounds of the memory test. Full 1GB shows up in the web interface.
Sped up my NV+ a fair bit. 32-35MB/sec during large file copies. :)
Bought the Patriot PSD1G33316S you linked to at NCIX, installed it in a ReadyNAS NV+ that was failing to take some rsync backups. Problem fixed, rsync is now doing fine.
For the next person googling, I leave this breadcrumb from my cronjob:
my Linux server talking to a ReadyNAS NV+ wrote:
rsync: writefd_unbuffered failed to write 4 bytes: phase "unknown": Connection reset by peer
rsync error: error in rsync protocol data stream (code 12) at io.c(836)
Fix that ^ with more RAM.
Consistent with randynas' note about DDR chip size, my RAM module had 16 chips on it (8 on each side).
Also I should note that if you plan to do this upgrade and perform the recommended 2 cycles of memory testing, you should budget at least 4 hours downtime for the tests to complete.
Thanks for the help, BikeHelmet, randynas et al.
