supracom
Jul 26, 2011Follower
1GB Memory for ReadyNAS NV
Hello, I searched extensively for a compatible DIMM for my ReadyNAS NV to upgrade it to 1GB. I already ordered a wrong module by guessing what type I needed so I would like to have a type-nr from s...
maxblack
Nov 23, 2011Aspirant
I wanted to upgrade my NV+ and had a LOT of trouble finding definitive information on what to buy. So I first took-apart my unit and found this:
Unigen UG032D6686LM-GJFHYN
256MB DDR400 SO-DIMM 200PIN
Then I searched (and searched, and searched some more) on 1GB SO-DIMMs with a CL of 2.5 and came-up with a grand total of one, which I found at Newegg.com:
AllComponents ACSO400X64/1024
1GB SC DDR-400
http://www.newegg.com/Product/Product.a ... 6820159414
Seeing a positive NV+ review there, and that it was only $29 bucks, made this a must-buy for me. Almost done with the 2nd test, after one successful one already--seems like a winner.
Apparently some here have been successful with other speeds (and 3.0 CAS Latency) but I am happy to find a 1GB chip that matches my old SODIMM.
1GB SC DDR-400
