supracom
Jul 26, 2011Follower
1GB Memory for ReadyNAS NV
Hello, I searched extensively for a compatible DIMM for my ReadyNAS NV to upgrade it to 1GB. I already ordered a wrong module by guessing what type I needed so I would like to have a type-nr from s...
PapaBear1
Jan 18, 2012Apprentice
Was it the same module?
How much newer is the second NV+?
You are right about memory upgrades being a gamble. I tried the 1GB module out of a 2004 HP laptop as it matched the specs. It worked great, but since I only used it as a file server without any add-ons, I noted no significant performance increase, and when I needed the laptop back, I returned the original memory module back to the NV+ and the 1GB back to the laptop. That was over a year ago now.
