supracom
Jul 26, 2011Follower
1GB Memory for ReadyNAS NV
Hello, I searched extensively for a compatible DIMM for my ReadyNAS NV to upgrade it to 1GB. I already ordered a wrong module by guessing what type I needed so I would like to have a type-nr from s...
youbecha
Feb 22, 2012Aspirant
youbecha wrote: I have two NV+ units. One came with 256M the other with 1G...So I opened the 1G unit to see what was installed...
MT16VDDF12864HY-335F2
http://www.micron.com/~/media/Documents/Products/Part%20Numbering%20Guide/215numsdrammod.ashx\
According to the Micron Technology data sheet, it is a 16 chip, 2.5V DDR SDRAM, DDR FBGA, 128 x 64, 200-pin SODIM, DDR333 FBGA, 167Mhz clock, 333MT/s Data band rate, PC2700, 2.5-3-3
The nice part, it the part number says it has 16 memory components...I am trying to find another one.
And I found one online, installed it and it booted nicely...running tests now.
